Results 1 to 14 of 14
Thread: 1G-GTE piston rings
    Default 1G-GTE piston rings
    Im about to rebuild my 1G-GTE but before I start, Im gathering parts. I have had a search for aftermarked piston rings but havent come up with an answer yet. I remember reading somewhere using 4K rings but you have to machine part of the piston? Any other aftermarked alternative?
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    Default Re: 1G-GTE piston rings
    Hi mate,
    I dont know of any performance rings for 1ggte i dont think, but why do you want better ones for? A new set of factory rings will tolerate a fair bit of hammering. Are your compressions really low now man? How many kms are on your engine at the moment? because the motor should tolerate your turbos comfortably.
    James
    Pretty sure Pube had a big end issue and is going to rebuild the whole lot!
    Compression was good before the big end but thought if rings wernt too expensive, they may as well be replaced since the engine will be pulled apart. Im prefer aftermarket, purely because they should be cheaper than genuine.
    these ppl seem to think that 4K pistons are very similar to 1G pistons
    http://www.rollaclub.com/board/index.php?showtopic=1955
    Backyarder! Grease Monkey
    umm its been covered before... depends if your pistons have the 2mm top groove or the 1.5mm...
    i have hastings 2mm rings in mine, hope that helps.... oh i got the off 6boost
    Agreed, I'll be getting the same piston rings.
    PLus I have a set of spare 1g-gte pistons incase yours are no good.
    Facebook | LinkedIn
    I priced some genuine rings today, they are ex Japan for AU$410. How much were the hastings rings?
    From what I remember, the hastings ones are around the $200 mark.
    Facebook | LinkedIn
    act
    genuine toyota rings in std from toyota can be purchased they are ex japan i recived a set approx 2months ago my cost 297.50 in frght from japan if you wish i can check supplier and stock check japan to suit 1ggze same cost for 1ggte
    Castle Hill Toyota quoted me $410 and 10 days from Japan. For $297 I would buy genuine.
    gtz1 - If you could see what you could do for me, that would be great!
    Quote Originally Posted by Pube
    FWOAR!...are they solid gold? with encrusted diamonds? your misse's must be a lucky girl!
    act
    have check with toyota there is stock in japan if required in 10 to 15 days air frght we pay frght landed $375.00 inc but sea frght 21to 25 working days inc frght $320.00
    Search for a thread about 6Boost running his 9 second pass.
    Page two has all the info on how he rebuilt his including the rings he used.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
  1. Tool to safely remove piston rings??
    Last Post: 07-03-2007, 12:26 PM
  2. Buying some new piston rings
    Last Post: 11-11-2006, 11:41 AM
  3. nissan CA18 piston rings on 3SGE?
    Last Post: 05-08-2006, 08:58 PM
