Results 1 to 10 of 10
Thread: 1ggze running rich, no idle controll
    Junior Member Backyard Mechanic 1jzracing's Avatar
    Default 1ggze running rich, no idle controll
    we just got a 1ggze conversion running in an old 22R corona but its running very rich and theres no idle controll,
    it was running so high it was hitting over run fuel cut and surging up and down so we manually turned the stepper closed so it would idle bit it doesnt have any controll its just static, wont idle when its cold etc.
    also its running really rich!
    anyone had experience with the wiring ???
    or is it more likely a faulty component??
    thanks
    a fool remains undescovered untill he speaks!
    Insert whitty comment her Automotive Encyclopaedia blacktop's Avatar
    Aug 2006
    Default Re: 1ggze running rich, no idle controll
    Might be a faulty sensor?
    I'm no standard management expert, but I'd tend to agree, a faulty sensor of sorts?
    Facebook | LinkedIn
    yea we tried a few temp sensor changes but no change, might make it rich but shouldnt affect the idle controll
    Forum Sponsor Conversion King
    Dec 2006
    have you checked that the stepper motor has power as it runs on a different circuit.
    (happened to me on the first 1g i did years ago.)
    thanks we havnt looked at that!
    maybe all it is
    still shouldnt be so rich, could be a totaly seperate problem
    Tasmania
    Check to see if the cold start injector isn't constantly working.
    AFM could be playing up?
    Is it running standard injectors?
    Is it throwing any error codes?
    Cheers Brett.
    thanks will check that out
    how do you tell if it has error codes?
    fixed
    actually 2 seperate problems
    it was the power supply to the stepper
    and it had a cracked injector seal, vacuume leak playing havoc with the oxy sensor
    funny how the hardest problems are sometimes the simplest things
    runs a dream now
    Dec 2006
    had that one sussed
  1. 1GGZE not running properly... Advice appreciated.
    By mic* in forum Tech and Conversions
    Last Post: 23-03-2007, 10:57 PM
  2. Will running rich screw up a new engine?
    By tooch in forum Tech and Conversions
    Last Post: 12-05-2006, 06:32 PM
  3. 4age running uber rich
    By EVOSTi in forum Tech and Conversions
    Last Post: 30-04-2006, 06:27 PM
  4. 2T-G Twin Solex TUNING help
    Last Post: 14-03-2006, 08:05 AM
