Results 1 to 10 of 10
Thread: Gearbox noises.. W55
    Default Gearbox noises.. W55
    Hey, i have recently chucked a 1ggte in my mz10 and bolted it up to the factory w55..
    basically i hear clunking noises when i back off in first, when i compression down shift, whenever i reverse.. sounds like something is hitting the trans tunnel..
    Box is a W55, N/A clutch.. on its way out, clutch needs a bleed, flywheel needs machining, slave cylinder may need rebuild.. Could any of this cause the noises..
    I know i should have changed the clutch when the motor/ box were out, but i needed a car for work and didn't have time/money to do so..
    The box only makes noise, i cant feel it restricting the movement of the car at all.. Apart from the clutch slipping at anywhere above 12psi..
    New clutch will be going in soon..before end of month
    What could these noises be?
    Stomps
    Default Re: Gearbox noises.. W55
    Have you checked the rubber gearbox mount? Sounds like it might be stuffed.
    ill have a look, but the noise sounds more mechanical..
    on a side note are w55 and w58 boxes interchangeable...
    If i have a bellhousing for a 1ggte off a w55 will it fit w58?
    Stomps
    Yes, completely.
    Western Aus
    stomps, you have GZ10, not an MZ10.
    just being a pain in the ass.
    Elmo.
    yes i do.. Goddamit.. i always say gz10, one time i type the wrong thing and get caught out..
    thanks capitan anal.. jks dude..
    so w55 and w58 interchangeable.. Are the lengths the same.. I dont want to have to modify the drive shaft..
    Stomps
    Western Aus
    dude, it sounds like your getting the noise whenever the motor kicks back from being under torque.
    maybe your exhaust is hitting something? or you've fucked your engine mounts up and the power steering/alternator/plenum/turbo is smashing against something?
    Elmo.
    actually now that you mention it, it could be the exhaust.. It rubs against where my feet sit and we actually had to give the floorpan some tough love with a hammer to make the zorst fit..
    It could be that, but somehow it feels like gearbox to me.. Dunno.. will have to have a look..
    I suppose that would explain why it does it more in first then any other gear, coz it drops more revs etc...
    Stomps
    W55 and W58 are the same length.
    W55, W56, W57, W58 & W59 are all identical from the out side and are the same physical size.
    (yes, 56 and 59 exist, but probably not in Australia)
    Western Aus
    well duh dude, its the exhaust hitting, when my exhaust scrapes on speed bumps and shit (pretty damn often!) i can feel it through the shifter.
    get some harder engine mounts.
    Elmo.
  1. Verifying a w58 gearbox
    Last Post: 09-10-2008, 11:39 PM
