Results 1 to 15 of 27
Thread: Internal turbo wastegate movement / clearance
    Default Internal turbo wastegate movement / clearance
    I've got some dump flanges for turbos (massive kudos to MrDOHC ! ). The flanges are designed (by me) to split the wastegate and main flow.
    I'm curious as to the range of movement the wastegate flap encounters in operation!
    Depending on how much movement the wastegate flap needs my design may cause the wastegate flap to hit my flange...
    It isn't a drama for me to modify the flange / wastegate outlet; and I suspect that going on the side of caution is what I should do, but I am still interested the answer!
    Pics to show what I mean!
    Default Re: Internal turbo wastegate movement / clearance
    It's doubtful that is will move that far, the stock wastegate on my CT9 only opens about 45 degrees at most, probably less. I did the same with my downpipe flange, and then put the wastegate actuator on and it didn't even come close.
    That being said you should test it with your actuator if you can, but I still doubt it will open quite so far.
    The thing is the exahust gases will push on the flap with a large amount of force which I can't really simulate out of the car.
    Simply applying pressure to the actuator won't really show what the movement will be in use (no exhaust gas pressure)...
    I did look at the actuator, and try and determine what the maximum extended length could be. Not knowing the internal design tho it looks like there might be enough movement to extend past the angle where the flange would block it...
    S.A
    I tend to agree with Talasas. There isnt much movement in them. The wastegate actuator rarely opens fully ( totaly extended) on any setup.
    Example : My old turbo would only push the gate open approx 45deg at over 9000 rpm.
    If you run a slightly larger pipe than the wastegate flap it should have plenty ov clearence for the flap to open all the way if needed any way
    The point you're missing is once it's attached to the actuator it can only move as far as the actuator allows it. You can simulate this by hooking up the actuator arm and pulling it out as far as it goes by hand. I figure won't open more than that.
    a bit of a side topic but have thought about making and installing a divider so that the exhuast wheel gases don't go near the wastegate?
    Quote Originally Posted by talasas
    OK, I wasn't sure if pulling on the actuator fully would damage it, but now I think about it can't see that it would
    Ta!
    I'll give that a go and see what the outcome is!
    Yep I'm already planning to do that
    then you can have the wastegate pipe just venting straight down.. screamer for extra noise
    Quote Originally Posted by RobertoX
    thats not quite what I had in mind but yeah you could do that
    apparently not having the wastegate air and exhuast air join for atleast 30cm is the optimum
    Pic is fully extended (looks about 45deg ish)
    You guys were well right
    If I was making them again I would have moved the wastegate circle closer to the top to allow a smoother flow for the wastegate gases...live and learn I guess
    S.A
    Cant you just grind it out with a die grinder ?
    Quote Originally Posted by 30psi 4agte
    Yes I could, but if I had of placed the hole further to the top when I designed then I wouldn't need to
    Also if I grind it out to an oval as opposed to a circle it will make the connecting of the wastegate pipe slightly more difficult.
    User Conversion King
    NWA
    oval the inside edge then.
    leave the pipe side of the plate round
    hello
    jeez - wilbo's small dremel will die carving out that plate? Or is that steel reasonably easy to grind?
    And do we get to call Phil Doctor Flange when we see him next?
    dremel would die...
    But new favourite tool = power file
    Indeed!
  1. Internal or External Wastgate?
    By toddw in forum Tech and Conversions
    Last Post: 24-12-2005, 08:30 PM
