Originally Posted by JustenGT8
thay are spring tensioners - loosen the 14mm bolt and lever it back with the inlet and exhaust gear you will see a little hole on one of the arms line them up with a notch on the bearing cap behind and on the crank gear line that line up with a notch on the housing. If you need more help let me know.
cheers Craig
