Results 1 to 7 of 7
Thread: Changing of 4AGE Valve stem seals
    Junior Member Grease Monkey .:2DR-FTU:.'s Avatar
    New South Wales
    Smile Changing of 4AGE Valve stem seals
    Hey guys,
    As topic states, how do i change valve stem seals, preferably without taking off the head?
    Quote Originally Posted by Cow Cow
    Here in Hong Kong, I have a Echo 1.3
    I put in a TRD exhaust manifold, TRD quick shift gear stick, K & N Air Filter, Ground Cable, NGK E spark plugs, 2 pcs of Voltage Stabilisers and twin HID systems.
    It goes like a rocket.
    Default Re: Changing of 4AGE Valve stem seals
    Tricky, but possible - I've done it on other engines, but not a 4AGE.
    There's two main ways, and they're both crappy.
    The most crappy is to get some plastic rope and stick as much of it down the sparkplug hole as you can, with the piston near TDC. Then turn the piston up to TDC so the rope is all tight in the chamber. That'll hold the valves up while you take the spring retainers off, etc.
    The slightly less crap way is to use compressed air.
    The pukka way is to remove the head and do it properly.
    www.billzilla.org
    Toymods founding member #3
    New South Wales
    Cool, thanks Mr. Zilla!
    S.A
    Do a search m8 this topic has been covered in depth before
    This is probably the best solution, not cheap but looks good.
    what? Automotive Encyclopaedia EVOSTi's Avatar
    ive never used the rope method, always use compressed air. but ive only done it on engines where you can get a valve spring compressor on the springs. on a 4age, youll need to make a leaver to compress the valve springs, wouldnt be too difficult if you take your time.
    Rope works like a charm, I've never had a problem with it.
  2. Valve stem seal replacement on 4AGE
    By SUP16V in forum Tech and Conversions
    Last Post: 10-09-2013, 05:55 PM
  3. 1JZ-GTE valve stem seals
    By rogue-vl in forum Tech and Conversions
    Last Post: 17-05-2010, 02:28 PM
  4. 18R Valve Stem Seals - Replacing Q's
    Last Post: 03-02-2006, 12:50 PM
  5. Changing 4AFC valve stem seals
    By broken22 in forum Tech and Conversions
    Last Post: 03-02-2006, 02:50 AM
