Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: 3SGE differences?
    MS
    Default 3SGE differences?
    I've looked, I've searched, and I've asked elsewhere and gotten FA for my trouble , so I thought I would come here and ask people who generally point me in the right direction.
    What are the Major differences between the 3SGE and the 3SGE Beams?
    I know beams has VVTi and the compression ratio is higher but mechanically speaking are those the only differences?
    The reason I ask is next season I plan on building a track car, the class requirements are
    1> Engine must be made by the Chassis MFR. I'm going to be building up a 77 Celica so it must be toyota
    2> Engine must have a capacity of < 2200cc
    3> Engine must be N/A
    looking at toyota engines that fit these requirements we get the 3SGE Beams and the 1/2 ZZ as the top performers, I've decided to go the 3SGE route and started researching a bit online, then I stumble across this
    3SG (SXE 10)
    HIGH COMP 2200 PISTON KIT
    3SG (SXE10)
    SPORTS INJECTION KIT Under development
    Found at http://www.toda-racing.jp
    With those and a good Cam setup would I be able to build a good race 3SGE with a Non Beams 3SGE?
    I dont know that the VVTi is going to make that huge of a difference esp. if i go with some hotter cams.
    The advantage of starting with a non Beams is the inital cost of the engine.
    Would standard 3SGE parts (Valves, springs, ect.) fit on a Beams engine ?
    RA65 SCCA Car (looking for a decent swap)
    NCP61 Daily Driver (pondering the practicalities of making it a SCP61)
    Default Re: 3SGE differences?
    PM celica RA45, he has a built Beams 3S for his race car!
    with the vvti i am fairly confident you should get the same peak hp (if u set it up for that), but the vvti will improve the area under the curve, hence making it a bit faster.
    27.90s @ Esses Hillclimb
    Junior Member Backyard Mechanic strat's Avatar
    Jun 2006
    s.a
    I have been "toying" with the idea of a RAV 4 motor i think they are 3S and VVTi, this might be a good option i wanted to put one in a RA40 for the street as i race a RA40 with a 3SGTE i have plenty of parts and could build one quite cheap. just be carefull with oil delivery caus every one that RWD's 3S's have oil problems caus the motor is on a 20 degree lean in FWD config but i ST185 MR2 motors dont seem to have this problem as they are not on so much of a lean from factory... Food for thought.
    S.M.R
    There is a method in the madness
    queensland
    check my web-site. lots of 3S info/pics. www.roadandtrack.net.au
    Junior Member Backyard Mechanic Dimitri's Avatar
    there are 5 versions of 3sge.
    gen 1s not really worth considering.
    gen 2 and 3 are good engines, gen 2s are a little easier to convert to rwd (they only came out in mid engine and fwd/4wd cars) for na and big cams ect gen 3s have the advantage of shim under the buckets stock.
    gen 4s are VVTi on one cam and are from fwd cars only also.
    gen 5 beams 3sge's are rwd only (to my knowlege) and are dual vvti. it isnt just the varying cam timing thats a bonus. the later and newer the head the better the port design, along with alot of other things inside the engine too. being rwd standard is also an advantage to you, offseting the extra cost somewhat because you wont be fooling around converting the engine to run rwd.
    depends on your budget i guess but if youre serious the beams makes alot of sense. to even get the non VVT engines upto the standard output of the beams will be some work.
    fitting is another thing to consider. for a race car you should be able to make it work, but be warned the engine is EXTREMELY tall. the sump is also offset forward quite a bit, making it a little bit of a trick to get the engine far enough bar to fit behind the sway bar (this is what we found in the ae86 we put one into anyway).
    ours made 128kw at the wheels, completely stock save for the intake manifold, which was only modified so the engine could fit in the car.
    if you do decide to go beams i think youll find adaptronic is the cheapest ecu available that can control the cams.
    as far as the stroker kit, i think youll find it will fit in almost any 3s? probably, but youll definately get varying compression ratios due to differant combustion chamber volumes atleast.
    Penrith BC
    what versions are there of the 3sgte?
    caldina gen 4 with dual vvti ??
    ../delete/ban
    tech moderator
    Talking Re: 3SGE differences?
    Quote Originally Posted by Dimitri
    Oh with a decient budget this would be my pic. (or a gen II 3SGTE converted to NA)
    You could fit a bus sideways through those inlet ports, (go the oldschool TVIS big ports) crank some 1ZZFE solid lifters in and away you go.
    in real terms though for a more respectiable budget the Black Top BEAMS is probably the way to go.
    TRD do a 270PS kit for them.
    yeah, check it http://trdparts.jp/english/parts_engine-3s-ge.html
    Jordan
    that is hot shit.
    p.s re gen 1. i dont know about the biggest port possible being the best thing.. and also the cam buckets on a gen 1 are the same size as a 4ag.. i.e not really big enough for really big cams.
    Jun 2006
    s.a
    i know this is an old thread but i really need some help. As we all know the 3SGTE is a hard engine to find but there are 3sge's everywere (in S.A anyway) now the problem i have is that spun a main baring and mabey more damage on the weekend, i need to rebuild my motor in 4 weeks (before the next race) but im looking for another motor. My question is how simmilar are the turbo and non turbo 3S MR2 motors. Ie could i buy a non turbo MR2 long motor and put all my manifolds injectors loom etc on the non turbo SW20 motor?
    S.M.R
    Jun 2006
    s.a
    or anyone have a low km 3SGTE for sale????
    S.M.R
    theres always tonnes of 3sgtes for sale at the importers !
    3sgtes i find are very very common these days.
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    Jun 2006
    s.a
    Quote Originally Posted by Jorrs
    Not in S.A and all importers sell half cuts and dont want to seperate. I just need a long motor, + if i can use non turbo motors i can get them cheap as!
    S.M.R
    serial biochemist Automotive Encyclopaedia
    Quote Originally Posted by strat
    ... there are 3sge's everywere (in S.A anyway)
    what generation are you talking about??? I have yet to see anything after gen 1 in a 3sge in SA and I was looking pretty seriously about 6months ago. Adelaide Jap usually have plenty of 3SGTEs in or out of half-cuts
    your rep rating is not a reflection of your worth to the community
    Quote Originally Posted by H1TMAN
    wtf? I want to do track racing, and f#@k you...
    that's very flattering but no thanks.
    Jun 2006
    s.a
    Quote Originally Posted by mtp_69_i
    Rang about 6 shops today, looking for a gen2 MR2 SW20. There are three non turbo motors i have found and no turbo, found 2 in queensland but they are half cuts and havent rang em yet to see if they will seperate. All i want to know is if i can use the bottom end out of another 3S motor and what is different between the non turbo and turbo motor i this what this thread is all about.
    S.M.R
    Jun 2006
    s.a
    S.M.R
  1. ST162 3SGE Swap (Photo Diary)
    Last Post: 07-10-2007, 10:38 AM
  2. nissan CA18 piston rings on 3SGE?
    Last Post: 05-08-2006, 07:58 PM
  3. Simple 3sge Mods
    By Lonewolf in forum Tech and Conversions
    Last Post: 18-02-2006, 01:47 PM
  4. Replies: 0
    Last Post: 30-08-2005, 08:43 AM
