I just used the Corona MKII bolts/nuts to hold the backing plate on.
I used the rubber section of the Advante brake line that goes onto the caliper and re-routed my original steel lines to suit.
Still trying to work out what to do with handbrake cables. I am using RA28 ones with the ends cut off, looped over, and crimped in place. Not working so well.
I removed the valve from the master cylinder that sits on the rear brake line. I used a 4 wheel disc brake bias valve. Seems pretty good but I think the rear brakes could have more bias. Might invest in a adjustable valve one day.
